CSCO10320953 Sat, 11/22/2008 - 06:30
After upgration IPS-4240-K9-sys-1.1-a-5.0-2.img to IPS-4240-K9-sys-1.1-a-6.1-1-E3.img i am getting below message
There is no license key installed on the IPS-4240. The system will continue to operate with the currently installed signature set. A valid license must be obtained in order to apply signature updates. Please go to http://www.cisco.com/go/license
to obtain a new license or install a license. Its not going to promt mode ?
How can i go to ips configuration mode?
Any steps which are to be done first?
Farrukh Haroon Sat, 11/22/2008 - 12:35
  • Red, 2250 points or more
Is there any specific error you are getting?
Did you upgrade directly from 5.0.2 to 6.1.1? You have to follow a specific upgrade path (mentioned in the release notes).....
An absent license should not prevent the sensor from going into the configure mode.
Farrukh
CSCO10320953 Sun, 11/23/2008 - 05:53
No specific error.
Yes.
Can u give me to follow a specific upgrade Path .
PL.
CSCO10320953 Sun, 11/23/2008 - 18:51
Model IPS4240.Below error only I'm getting.After that i'm unable to do any thing except switch off and switch on.
Farrukh Haroon Sun, 11/23/2008 - 21:53
No this is just a regular message seen on EVERY sensor without a valid license.
There has to be something more. Or else you have to
> Open TAC Case
> Re-Image the appliance using the recovery media
Farrukh
CSCO10320953 Wed, 11/26/2008 - 19:22
I have found out that there is a key required for IOS upgrade version5.1 to 6.1
