ether channel load balancing
Answered Question
Nov 21st, 2008
hi every body!
let say two switches sw1 and sw2 have two hosts h1 and host h2 respectively. sw1 is connected to sw2 by trunks, we establish etherchannel on the trunks.
If isl is used for trunking, and ether channel is using src-dst-mac as load balancing method, will ether channel use source and destination mac in isl header to determine the link in etherchannel or it will use the source and destination mac belonging to hosts ?
How about in case of dotiq trunk which inserts only 4 byte tag in ethernet frame, would ether channel use the source and destination mac belonging to hosts for load balancing?
thanks a lot!
Correct Answer by Mark Yeates about 8 years 3 months ago
Sarah,
I beleive that the load balancing in host based to maintain the load balancing.
source-MAC address forwarding, when packets are forwarded to an EtherChannel, the packets are distributed across the ports in the channel based on the source-MAC address of the incoming packet. Therefore, to provide load balancing, packets from different hosts use different ports in the channel, but packets from the same host use the same port in the channel. With destination-MAC address forwarding, when packets are forwarded to an EtherChannel, the packets are distributed across the ports in the channel based on the destination host MAC address of the incoming packet. Therefore, packets to the same destination are forwarded over the same port, and packets to a different destination are sent on a different port in the channel.
HTH,
Mark
Overall Rating: 5 (1 ratings)
sarahr202 Fri, 11/21/2008 - 18:46
thanks for your reply!
here is isl header
SA/DA/TYPE/USER/NLAN ID/ETHERNET FRAME/FCS
where SA source mac address of the switch which appends the isl header.
DA destination address which is a multicast address.
In my opinion,etherchannel looks at source and destination mac addresses of hosts, then determine the link in etherchannel, once the link is determined( which is in our case is trunk), then proper header (if isl is used) or tag( if dotiq is used) is inserted in the frame and then frame get transmitted on the link.
every body is welcome to correct me.
thanks a lot!
Correct Answer
Mark Yeates Fri, 11/21/2008 - 19:38
Sarah,
HTH,
Mark
