Static Route
Nov 21st, 2008
I have 2 subnets (192.168.1.0/24 and 192.168.2.0/24) on RouterA. How can I tell my routerA to take all traffic from my local 192.168.1.0 and route it to my S0/0 inteface which connects to routerB? Thanks in advance.
Overall Rating: 4 (1 ratings)
sdoremus33 Fri, 11/21/2008 - 19:38
  • Bronze, 100 points or more
You can apply Policy Based routing scenario
ex: Create Policy via Route Map
Route Map #nameofmap permit 10
match ip access-list 10
set ip next hop || set interface s0/0
ip access-list 10 permit ip 192.168.1.0 0.0.0.255
Note: In the set clause section you can specify the interface as so/0 for directing packets outbound via to RouterB
davidhuynh5 Fri, 11/21/2008 - 19:58
Sorry. I'm not too familiar with Policy-map. Do you have a link that easily explain it?
Thanks.
sdoremus33 Sat, 11/22/2008 - 10:02
You can think of Poicy Based Routing is a mechanism used to suprcede normal routing baed upon the Pociy map you enforce
This is a basic rundown of what happens
1) You create a policy map that first specifies a permit line. The order in which permit lines occur are baesd upon numerical value, so if I specified a permit line of 10, 20,30, then the policy map would read line 10 first,20, then 30 in succession.
So in my previous example
Route map test permit 10 /* permit 10 first */
The next clause is the match clause. You can use a regular IP access-list 1-99, because we are only dealing with the source ip subnet range. If you wish to match based upon Port, DSCPvalue, etc..then you would use an extended access-list
Lastly the set paramter is used to set in this scenario the interface serial0/0 to carry the ip subnet 192.168.1.0 to Router 2
So in summary
Add the route map (PBR)
(Line 1)Route-map testtraffic permit 10
This sets the permit statement to read Line 10 first then subsequent permit statements would be read in order of numerical value
(Line 2)Match ip access-list 10
If there is an ACL list match for acl 10 then the Next line Line(3)will apply that traffic over the specified interface (serial0/0
(Line 3)Set interface serial0/0
Based upon the ACL match ACL10, then set traffic to traverse over serial0/0 interface to RouterB
This is the ACL I spoecified in Line 2, remember if there is a match based upon the subnet information given in teh Access-List under the match clasue then proceed to the set clause
Here is an additional link to help out
