By default, there are three command levels on the router:
⢠privilege level 0-Includes the disable, enable, exit, help, and logout commands
⢠privilege level 1-Includes all user-level commands at the router> prompt
⢠privilege level 15-Includes all enable-level commands at the router> prompt
You can move commands around between privilege levels with this command:
privilege exec level priv-lvl command
