cisco 7206 ios
Answered Question
Nov 22nd, 2008
Hello i was buy cisco 7206 and i have smartnet for 7206
ios for 7206 have bug howe can i download general deployment ios gor 7206
Correct Answer by JORGE RODRIGUEZ about 8 years 6 months ago
With smartnet you should be able to have a cco login account and go directly to software download area
Pick IOS software on left hand side
http://www.cisco.com/kobayashi/sw-center/index.shtml
Also on same link above, if you do have the bug ID you can go to bug toolkit database and quary the bug ID to know exactly the version code it has been fixed.
If you have smarnet but do not have cco login to access download area, contact Cisco TAC services directly
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sat, 11/22/2008 - 07:39
  • Green, 3000 points or more
Rgds
Jorge
m.govorov Sat, 11/22/2008 - 11:33
hello
thank you
but i can't find general deployment release
is it possible donwload gd ios from site
ajagadee Sat, 11/22/2008 - 12:21
  • Cisco Employee,
Yes, it is possible to download GD code from the above site. What GD release are you trying to download.
If its 12.4 Mainline, then there is no GD Code available. Refer the below URL for details.
Cisco IOS Software General Deployment (GD) Program Retirement
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6968/ps6350/product_bulletin_cisco_ios_software_gd_program_retirement.html
Arul
*Pls rate if it helps*
