Need change int d0 MAC address
Nov 22nd, 2008
How change MAC address after "bia"?
000f.f858.a9b5 (bia 000f.f858.a9b5)
command
conf t
int d0
mac-address AA.BB.CC
only change MAC address before "bia"
gamccall Mon, 11/24/2008 - 05:18
  • Silver, 250 points or more
BIA means "burned-in address". You can't change the BIA.
serg_russ Tue, 11/25/2008 - 07:09
And what do next block
conf t
int d0
mac-address 1122.3344.5566
What reason ??
gamccall Tue, 11/25/2008 - 07:37
That changes the mac address on that interface, for almost all practical purposes. If you set a custom mac address on an interface, the new mac will be used in preference to the BIA for everything except a few commands where you have the option to specify use of the BIA.
I can think of very few honest reasons for spoofing a mac address, though. What are you trying to accomplish?
serg_russ Wed, 11/26/2008 - 02:55
Just few MAC addresses our wireless network registered in control organisation. After this summer we lost this devices (into strong thunder). And register again will be a long time ))
Just bureaucracy situation
And just technical interes )
John_from_obninsk Wed, 09/23/2009 - 01:25
Hello, we have the same problem. How to change MAC-address on int do0 while Do0 in root access-point mode? Command mac-address xxxx.xxxx.xxxx doesn't do any changes even with shut/no shut. After no shut "show int do0" show that bia mac-address is active.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
