11-22-2008 11:09 AM - edited 03-14-2019 03:17 AM
Hi!
When a call is in a queue is it possible to have some music between messages?
Ana
11-22-2008 04:30 PM
Of course. What platform are you using - UCCX, UCCE with IP IVR, UCCE or with CVP? All three are somewhat different, although IVR coding in the first two is very similar.
Geoff
11-23-2008 07:28 AM
With CCX you can use the Hold and Unhold steps. These will use whatever MoH source is configured on the CTI Ports (or the system defaults if not overridden at the CTI Port level).
An example would look like this:
Queued [Label: QUEUED_LOOP]
--Prompt
--Hold
--Delay X seconds
--Unhold
--Goto QUEUED_LOOP
11-24-2008 02:19 AM
Ok. Thanks!
