Urgent!!!! Voice Gateway was hacked, were made thousand of L.D Calls
Nov 22nd, 2008
I have several 2800 Voice Gateways in several regions. How can I protect my H.323 GW? these Gateways have public IP addresses. Can I control or Authenticate my VOIP Gateways in order to eliminate a rogue Gateway can connect to my Gateway and they can make calls?
Overall Rating: 5 (2 ratings)
wong.jason Sun, 11/23/2008 - 16:10
You need to at a minimum create an ACL to prevent H323 traffic that originate from the internet from going into your gateway and only allow those from your sites.
heshengchun Sun, 11/23/2008 - 18:21
As far as I know. GK is the only solution. Access-list can not prevent Dial peer hacking
tim.giles Mon, 11/24/2008 - 03:02
  • Silver, 250 points or more
I don't know whether this is a possibility but you could add a gatekeeper to authenticate requests via AAA? That way all the gateways would have to securely register with the gatekeeper.
This can also be intergrated with a radius server (i.e. ACS) if you have one?
dmendoza Mon, 11/24/2008 - 07:23
I appreciate you response, would you have a link with a example of how integrate the GK with CSACS in what version of CSACS is?
Do you know the IP address of all gateways authorize to send calls (signaling) to the other one? if so, you may consider an access-list.
if the answer is yes, you may consider somthing limiting access per port per IP address for example. here is some port information to assist you:
H.323/H.225 = TCP 1720
H.323/H.245 = TCP 11xxx (Standard Connect)
H.323/H.245 = TCP 1720 (Fast Connect)
H.323/H.225 RAS = TCP 1719
SCCP = TCP 2000-2002 (CM Encore)
ICCP = TCP 8001-8002 (CM Encore)
MGCP = UDP 2427, TCP 2428 (CM Encore)
SIP= UDP 5060, TCP 5060 (configurable)
I get it from http://www.cisco.com/en/US/tech/tk652/tk698/technologies_configuration_example09186a0080094af9.shtml
regards,
daniel
heshengchun Mon, 11/24/2008 - 08:07
Daniel,
Access-list is not good idea to prevent dial peer hacking. Here is one scenario - Both A and B need send H.323 calls to C, how can you use access-list to prevent A hacks B's account in C?
heshengchun Mon, 11/24/2008 - 08:54
Daniel,
The scenario I mentioned is indeed for hacking from outside. I thought AAA is not power enough to prevent such attack. Could you advise how to use AAA in such scenario?
isahonen Tue, 11/25/2008 - 01:28
HI
You can use source-ip based dial-peer to using voice source-group, access-list and translation rules.
Example:
voice source-group customer1
access-list 50
translation-profile incoming 50
voice source-group customer2
access-list 40
translation-profile incoming 40
rgds,
Ismo
dmendoza Tue, 11/25/2008 - 08:15
I was looking for a complete example of this command voice source-group, but I dont find it. So this command is for using a ACL where you specify the IP of Remote Gateway in order to ensure only this Gateway can do calls for the translation profile?
Could send me more details how use this command, by the way I have a CS ACS for AAA.
The challenge is be able to identified or permit the uses of the prefix for client but only from a known ip address of GW.
isahonen Wed, 11/26/2008 - 00:48
Below are simple example, where prefix 7 or 8 are added to using that feature.
access-list 1 permit 1.2.3.4 0.0.0.255
access-list 2 permit 3.4.5.6 0.0.0.255
voice source-group 1234
access-list 1
disconnect-cause invalid-number
translation-profile incoming 1
voice source-group 3456
access-list 2
translation-profile incoming 2
voice translation-profile 1
translate called 1
voice translation-profile 2
translate called 2
voice translation-rule 1
rule 1 /^1\(.*\)/ /81\1/ type any subscriber plan any isdn
voice translation-rule 2
rule 1 /^1\(.*\)/ /71\1/ type any subscriber plan any isdn
dial-peer voice 1 voip
destination-pattern 8T
dial-peer voice 2 voip
destination-pattern 7T
heshengchun Wed, 11/26/2008 - 06:00
I think this solution is good for IP2IP scenario, what about IP->TDM?
Suppose ISDN T1-A must take calls from IP 1.2.3.4/24 and ISDN T1-B must take calls from IP 3.4.5.6/24.
heshengchun Wed, 11/26/2008 - 06:18
Daniel,
Be patient. what you described is exact what I called dial-peer hacking. Do you know how much money IDT lost due to the dial-peer ( tech prefix ) hacking?
Sir,
Maybe I'm missing something here but if you combine the tech prefix match with the voice source-group command (or access list), you will limit the access to the gateways only to IP addresses that belong to your company and tech prefix will be used not to block calls but to deliver it correctly in a specific E1 or T1.
regards,
Daniel
heshengchun Wed, 11/26/2008 - 06:33
In fact we only need one POTS dial-peer to terminate VOIP->TDM call, therefore simple access-list and tech prefix open hole for the dial-peer hacker. As for how to use voice source-group to prevent such attack, I do need advise.
I try this command in a similar equipment and it works like this:
to block a specific IP, returning to these calls user-busy, and allow all other IPs to send calls, you can build an access list like this:
access-list 1 deny x.x.x.x
access-list 1 permit any
than using the command suggested by our colegue, we include the access list reference and the disconnection cause desired for the block calls:
voice source-group secured
access-list 1
disconnect-cause user-busy
you can invert the access list and allow just some specific IP addresses to send calls.
I hope this can be useful for the subject.
regards,
daniel
heshengchun Wed, 11/26/2008 - 08:57
let me repeat -
Suppose ISDN T1-A(for long distance) should only take calls from IP 1.2.3.4/24 and ISDN T1-B(for local) should only take calls from IP 3.4.5.6/24. How can you do to prevent calls from 3.4.5.6 to dial long distance call?
suppose the termination gateway IP is 9.9.9.9
at gateway 1.2.3.4, dial-peer should be something like:
dial-peer voice 100 voip
destination-pattern 0T ! if numbers start with 0 for example
session target ipv4:9.9.9.9
tech-prefix 100#
at gateway 3.4.5.6, dial-peer should be something like:
dial-peer voice 200 voip
destination-pattern .T ! if numbers start with any digit for example
tech-prefix 200#
at local gateway we will put
! secure to just receive calls from these classes of IP:
access-list 1 permit 1.2.3.4 255.255.255.0
access-list 1 permit 3.4.5.6 255.255.255.0
access-list 1 deny any
access-list 1
! each dial-peer to each e1:
translation-rule 100
rule 0 100#0 0
! this is in a very extended way and not allowing 0
translation-rule 200
rule 0 200#1 1
rule 1 200#2 2
rule 2 200#3 3
rule 3 200#4 4
rule 4 200#5 5
rule 5 200#6 6
rule 6 200#7 7
rule 7 200#8 8
rule 8 200#9 9
rule 9 200#1 1
! terminate in ISDN T1-A
dial-peer voice 100 pots
translate-outgoing called 100
port 1 (should replace by correct port identification)
! terminate in ISDN T1-B
dial-peer voice 200 pots
translate-outgoing called 200
port 2 (should replace by correct port identification)
heshengchun Wed, 11/26/2008 - 09:37
suppose I can access 3.4.5.6 and I want to dial free long distance, so I add this dial-peer
in 3.4.5.6
dial-peer voice 300 voip
tech-prefix 100#0
Jack,
This was in the supposition that you have gateways proteceted but even with that, if you go back to "isahonen" example, you can do to different voice source-group, associate a different access list with each of them and than associate different voice translation-profile with each one:
access-list 1
access-list 2
translate called 1
translate called 2
heshengchun Wed, 11/26/2008 - 10:17
Daniel,
Did you really test "isahonen" example before drawing conclusion? BTW, 3.4.5.6 is my GW and I'd like to test security of 9.9.9.9
yes, I test the following exact configuration:
voice translation-rule 100
rule 1 /^100#81/ /81/
rule 2 /^.*/ /8888888/
voice translation-rule 200
rule 1 /^200#81/ /81/
rule 2 /^.*/ /88888888/
voice translation-profile 100
translate called 100
voice translation-profile 200
translate called 200
access-list 1 permit 1.2.3.4 0.0.0.0
access-list 2 permit 3.4.5.6 0.0.0.0
access-list 2 deny any
access-list 1
translation-profile incoming 100
voice source-group secured2
access-list 2
translation-profile incoming 200
this example is based on calls to country code 81 and if it's not 81, I block it, translating it to 888888.
regards,
daniel
heshengchun Wed, 11/26/2008 - 20:09
Interesting, you can test without building POTS dial-peer.
heshengchun Wed, 11/26/2008 - 21:57
I will test source-group as well. Again, simple access-list and tech-prefix combination without voice source-group definitely has security issue.
heshengchun Thu, 11/27/2008 - 07:27
When we talk about security of GW 9.9.9.9, GW 3.4.5.6 could be any 'innocent' or 'bad' individual. Therefore in security discussion of termination GW, we should consider all potential scenarios.
dmendoza Thu, 11/27/2008 - 08:35
Thanks for yours comments and interesting examples, but nobody has made much examples or links how configure a Gatekeeper with Authentication with AAA using CSACS. Is it a good alternative, if the mayority of the Gateways have Publics IP Address?
Is it possible to Register and Authenticate H323 Routers and SIP end points with GK at the same time? Does Cisco GK only support H.323 or can support SIP endpoints?
dmendoza Thu, 11/27/2008 - 09:29
I found this about GK:
Gatekeeper Features
The following sections describe the main features of a gatekeeper in an H.323 network:
• Zone and Subnet Configuration
• Terminal Name Registration
• Inter-Zone Communication
• Endpoint Identification via RADIUS/TACACS+
• Accounting via RADIUS/TACACS+
• Inter-Zone Routing Using E.164 Addresses
I was wodering if someone has configured this capabability :
This feature apply for users for billing porpouse in a internal Network or could be used to authenticate Gateways, too?
I have a billing system but I am not Authenticating Gateways, my endpoints in my case are others Gateways with TDM E1/T1 using others Gateways not user with a only one Phone.
Nicholas Matthews Sat, 12/13/2008 - 15:07
  • Red, 2250 points or more
I think this needs some clarification, because it can be a very important issue.
First, I would check out this tip:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
Then, you need to understand these basics:
H323 will respond to any request on any interface on TCP port 1720 by default. This applies even if you have the bind command.
SIP will respond on any IP address on UDP/TCP 5060 by default as long as the router has a voice-port. If you bind the media address, SIP will only respond on that address.
This means in short - even if you're running an H323 only gateway, you are still capable of bouncing incoming SIP traffic out your dial peers. It is very common to see a H323 only gateway with a .T or 9.T pots dial peer, and attackers hit the public IP address, it matches an incoming voip dial peer (or dial-peer 0), and then the wildcard matches the PSTN pots wildcard dial peer.
If you have a public IP address, make sure that you disable all SIP traffic on TCP/UDP ports 5060. You can use 'show tcp' or 'show ip socket' or 'show udp' to see some of the open ports.
HTH,
Nick
