E1 to DS0 in Groomer 15454
Nov 22nd, 2008
Is there any card available in cisco 15454 that can groom at DS0 level..basically i have channelized E1 circuit and i want to groom data channels(timeslots) to one device and voice channels(TDM timeslots) to other...both are in same E1, is there any support for this on Groomer...if not what device can do that....??
Tom Randstrom Sat, 11/22/2008 - 17:51
  • Gold, 750 points or more
The only card in the 15454 that has visibility to the DS0 level is the IP RAN card designed for cell site applications.
http://www.cisco.com/en/US/solutions/collateral/ns341/ns523/ns675/ns329/data_sheet_c78-473195.html
If you are looking for a single E1, you might try using a router. The following T1/E1 card that installs in a 1700 series router looks like it might be on the right track. There are cards available for other router series that would handle larger numbers of DS0 traffic.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088715.html
