Need to provide connection from Outside to the Web Server in the DMZ
Nov 22nd, 2008
Hi Friends,
I need a kind help. I have to publish a Portal Server to the Internet. The portal is in a DMZ Zone of ASA 5540, Outside connecting to the Internet.
I have to access the same server from Inside network, and from some other DMZ Zones of the same ASA as well.
Kindly need your help, what else i should add on the Firewall to make this possible. As of now there is no NAT statement, only NAT 0.
Also, I need to provide internet connection to all LAN Users.
Thanks a lot
Jacob
vishwancc Sat, 11/22/2008 - 23:40
Hi ,
The way to do it is do static natting
static (dmz,outside) X.X.x.x 192.168.2.102 netmask 255.255.255.255 where X is public ip for the server .
create a object group and match services to that if you need people want to access.
Chao
Vishwa
Jacob Samuel Sat, 11/22/2008 - 23:45
Thanks Vishwa,
So Static NAT, Access list, Route these are the things we need for this or any thing else more?
I need to know about the order of the NAT-ing. And how the access list would be ?
regards
Jacob
