I am getting HOSTFLAPPING error
Nov 23rd, 2008
18:27:43: %C4K_EBM-4-HOSTFLAPPING: Host 02:01:00:00:00:00 in vlan 1 is flapping
between port Te5/2 and port Te5/1
kindly provide the solution ASAP.
Please help
crow930us Sun, 11/23/2008 - 01:06
  • Bronze, 100 points or more
Cisco's Output Interpreter gives this:
%C4K_EBM-4-HOSTFLAPPING (x1):Host [mac-addr] in vlan [dec] is flapping between
port [char] and port [char]
Explanation: The specified host is detected as a source address on multiple ports.
Typically, a host is supposed to be learned on only one port. A spanning tree
loop is the most common cause of this condition. All traffic from the specified
host is temporarily dropped. After 15 seconds, forwarding is reenabled. If the
problem persists, the traffic from the problem host continues to be dropped indefinitely.
Recommended Action: Make sure that spanning tree is enabled to prevent spanning
tree loops. If you have spanning tree disabled, make sure that you have no spanning
tree loops in your network.
vishwancc Sun, 11/23/2008 - 04:29
If i am right you are doing some Microsoft Network Load Balancing and it is connected to the port Te5/2 and port Te5/1 ,it seems there is some Teaming issue with the Server ,get it checked from the server team .
Chao
Vishwa
