11-23-2008 12:30 AM
Am upgrading my cisco MDS9513 firmware from 3.0.2(b) to 3.2.3(a)..I get following errors when i start the installation,have done installation successfully on other switches,but this switch in particular throws the error.
Appreciate your help..Thanks
Setting boot variables.
[# ] 0% -- FAIL. Return code -1.
Install has failed. Return code 0x4093000C (Setting boot variables failed).
Please identify the cause of the failure, and try 'install all' again.
Solved! Go to Solution.
11-24-2008 04:19 PM
Most of the time this is caused by a syntax issue with the 'install all' command.
Please ensure that the kickstart and main SAN-OS image are on the active supervisor bootflash and then issue this command from the command line.
install all system bootflash:m9500-sf2ek9-mz.3.2.3a.bin kickstart
bootflash:m9500-sf2ek9-kickstart-mz.3.2.3a.bin
Follow the prompts and at some point you will need to enter Y to continue.
I have seen where the module number, or sup-local was used in the install command and it caused problems.
Hope this helps,
Mike
11-24-2008 04:19 PM
Hope this helps,
Mike
11-24-2008 06:30 PM
Thanks Mike,the solution turned out to be almost the same what you suggested..I opened up a case with Cisco and here is what he suggested.
CSCsr12337
install all Return code 0x4093000C when //sup-local files used
Symptom:
the upgrade process will fail if the "install all" command
is given a module location as part of the image uri. eg:
install all kickstart bootflash://sup-local/image_filename
Workaround:
do not use module locations when specifying image uri's.
The command "install all..." may eventually also fail thereafter
with the same error code, even if not using the prefixes //sup-local/ etc.
This may happen if the boot variables on the standby already contain
these prefixes - this can be checked with "show boot" and to see
which is the standby use "show mod".
Here is the procedure how to recover from that scenario:
1. Remove the incorrect boot statements:
conf t
no boot kickstart
no boot system
if that is accepted, go directly to step 4.
Otherwise if the switch returns:
failed to clear bootvar kickstart ( or system )
then go to step 2:
2. In that case you first need to perform system switchover:
- make sure that "show system redundancy status" shows the system
is in "operational: HA" state
- issue "system switchover"
- wait until the system returns to HA state as above
3. Remove the incorrect boot statements:
conf t
no boot kickstart
no boot system
4. Restore the correct boot commands
conf t
boot kickstart bootflash:old_kickstart_filename system bootflash:old_system_filename
exit
5. issue "copy run start"
After the above - the upgrade should go through this time.
As per the defect CSCsr12337 mentioned above - this issue
should not happen even when using the absolute paths
- in the software versions that have the fix ( 4.1(2) and later ).
In earlier software versions, when hitting this issue
