cisco aironet RM1252 11g webinterface
Nov 23rd, 2008
i am having one cisco aironet 1252 11g accespoint.when connecting to dhcp is getting an ip,but i am not able to open it through webinterface .also i tried console (using putty),but unable to go to configuration mode.
please help what will be the problem..
Vinay Saini Sun, 11/23/2008 - 06:22
Hii
I am assuming that is Autonomous AP. Try enabling HTTP on the AP by using command
ip http server in global config
Give it a try ..
vinay
aakhilsameer Mon, 11/24/2008 - 20:51
hi
but i have problem with CLI also..i cant go into global configuration mode...its blocking me when entriung config t..
gamccall Tue, 11/25/2008 - 08:11
Are you sure your 1250 is running IOS and not LWAPP? Can you paste a SHOW VER here?
