interface profile failed
Nov 23rd, 2008
Dear folks,
I have some AP's [1250],connected to WiSM, which shows the status of some interface profile failed and noise profile.
Some AP's[5/60] shows interface profile failed and some AP's [8/60] shows noise profile failed. What would be the reason for it ?
How can I correct it ? Waiting for your response.
Vinay Saini Sun, 11/23/2008 - 06:12
Hii Siddharth ,
There is Threshold for noise/Interference which u can set for each Radio type , when the noise level exceeds that value , then u will the noise profile failed.
To confirm , you can go to Monitor->802.11->select AP and find what is the noise detected for diff channels.
