Syslogs server for ASA 5520
gandhi.ganesh
I want to capture the logs of ASA 5520 to syslog server.
I want any free syslog application & it should be GUI based for windows
can anyone help me....
JORGE RODRIGUEZ
Level 10
Level 10
I use kiwi syslog free , for realtime syslog dumps, Im sure there are other free ones out there.
http://www.kiwisyslog.com/?source=yahoo
BTW.. you also have the option to send syslog to ftp server as well.
Rgds
Jorge
Jorge Rodriguez
7 Replies 7
JORGE RODRIGUEZ
Level 10
Level 10
Rgds
Jorge
Jorge Rodriguez
Here is good syslog app and much much more.
They just recently came out with a windows version.
http://www.splunk.com
Good for large environment or for small debugging using your workstation. Great for searching for specific info or reporting.
Enjoy!
Chad
you can also email syslog events (though you proabaly don't want all of them emailed).
Let me try & get back to u
hi, re syslog server, can someone advise what would happen to the ASA's if for any reason, the syslog server went down?
Would the firewalls still be operational not?
HiSuleiman ,
Yes ASA will still function.
DAK
Hi David
thanks for the reply
