To upgrade IOS at one goal to 2950/3560 switches
cindylee27
Hi Experts,
I would like to know if there is any softwares/tools (which is free) that can do a one goal updates from the remote end so that we don't need to do from one switch to another switch?
Thanks.
cindy
yes, it will not push IOS. It will only get the results for show commands/modify config for many davices at one time.
5 Replies 5
satish_zanjurne
Level 4
Level 4
CiscoWorks (RME)Resource Manager Essential should be able to do that.
HTH..rate if helpful..
Thanks Satish!
If I have token to authenticate each login,meaning needs to have admin rights how can i do this?
And is this free?
Thanks again!
You can use Kiwi Cat Tools to perform checks like login/ get results of show commands etc..
this is free.
Cisco Works Resource Manager Essentials needs to be purchased from Cisco.
regards,
Thanks man..
but checked that this tool can't do IOS push down right?
