Change ipsec peer ip address
Answered Question
Nov 23rd, 2008
Haven't done this in a while and am a little rusty. Need to change the ipsec site to site peer address on a tunnel, a one router is changing locations/ip address.
The current cryptomap config is :
crypto isakmp policy 11
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 12
hash md5
crypto isakmp key abc12345 address 206.169.4.20
crypto isakmp key XXXXX address 66.194.7.3
crypto isakmp key XXXXX address 66.162.45.164
crypto isakmp key XXXX address 168.215.214.202
crypto ipsec transform-set set1 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 20
set transform-set set1
match address 120
crypto map map1 local-address Serial1
crypto map map1 client configuration address initiate
crypto map map1 client configuration address respond
crypto map map1 11 ipsec-isakmp
set peer 206.169.4.20
set peer 66.194.7.3
set peer 66.162.45.164
set peer 168.215.214.202
match address 120
The current address of the router that will be changing is 66.162.45.164
I think all I have to do once they get the router at the other end configured is to change the 66.162.45.164 address in the cryptomap to the new ip address, is that correct?
Correct Answer by ajagadee about 8 years 7 months ago
Yes, that is correct. Also, make sure that you configure the crypto isakmp key with the correct Pre shared key and IP Address.
set peer NEWADDRESS
crypto isakmp key XXXXX address NEWADDRESS
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Sun, 11/23/2008 - 21:42
  • Cisco Employee,
set peer NEWADDRESS
Arul
