6500 modules
Nov 23rd, 2008
Is there a command to show if a module has been restarted. I'm having a problem with one of my customers system and the staff nor I have a good understanding of how to look to see if the module is having probles. Any help would be greatly apprecitated. TIA
vishwancc Sun, 11/23/2008 - 21:42
Give show logs which will give you information on module restart.
Chao
Vishwa
johnlloyd_13 Mon, 11/24/2008 - 05:39
adding to what vishwa said, try to issue the command show module and it will show you the status of each module. we recently had a problem in one of our PoE module and a syslog looks like this:
%C4K_SWITCHMANAGER-4-S2WERRORREPORT
after we did a software reset, syslogs will show you this:
*Oct 27 13:02:57: %C4K_IOSMODPORTMAN-6-MODULEOFFLINE: Module 5 is offline
*Oct 27 13:02:58: %C4K_IOSMODPORTMAN-6-MODULEREMOVED: Module 5 is removed
*Oct 27 13:03:02: %C4K_IOSMODPORTMAN-6-MODULEINSERTED: Module 5 is inserted
*Oct 27 13:03:04: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 5 (WS-X4248-RJ45V S/N: JAE1028686W Hw: 3.1) is online
andrew.burns Mon, 11/24/2008 - 06:01
You can use this command:
show diagnostic events
After initial booting of the switch you should get an entry every time a module initialises.
Andrew.
