Restricting SSID to certain APs?
shave
Can I map an SSID to only be broadcast on certain AP's from a 4404 controller? Seems like was able to do this in early releases but can't seem to do it now, just the AP group function..
gamccall
Level 4
Level 4
The WLAN Override feature is still available- if you're not seeing it in the Config-AP menu, try checking under the Config-Radio-Interface menu.
Note that WLAN Override is planned for deprecation in future releases, so you might want to just bunch your APs into AP Groups now.
gamccall
Level 4
Level 4
