WEP to WPA
John Blakley Mon, 11/24/2008 - 11:51
  • Purple, 4500 points or more
If you want to use just one vlan, then you would need to set under your SSID:
authentication open
authentication key-management wpa
wpa ascii key
Under your radio interface:
int do0
encryption vlan 1 mode ciphers tkip
HTH,
John
John Blakley Tue, 11/25/2008 - 03:34
Yes. When the clients "switch over", they're going to lose association with the AP. You'll have to change the encryption type under the client from wep to wpa-psk (if windows).
HTH,
John
John Blakley Wed, 11/26/2008 - 05:10
You may be able to do that, or through GPO, but I'm not a big Microsoft guy. You'll probably want to contact them to see if there's a way to do this through scripting of some kind. Otherwise, you'll need to send a message out to all of your users describing how to switch over to the new security method.
HTH,
John
