Joe Clarke Sun, 11/23/2008 - 23:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. Once a device is deleted from DCR, it cannot be recovered unless you have a backup of LMS which included that device.
That said, you can always re-add the device. However, none of the previously archived configs, inventory, etc. will be recovered.
Joe Clarke Mon, 11/24/2008 - 00:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I said in my previous post, the only way to recover is restore from backup.
Joe Clarke Mon, 11/24/2008 - 00:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can add devices manually or import them in bulk from a CSV file. Both are done under Common Services > Device and Credentials > Device Management.
jeeyishyuan Mon, 11/24/2008 - 00:49
I have previously exported the csv file for all reachable devices. However, I was prompted the error of invalid file format when I did a bulk import. Why is it so?
Joe Clarke Mon, 11/24/2008 - 08:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It sounds like you modified the exported CSV file. The exported file contains a header that must be preserved in order to be reimported. If this header is removed or corrupted, then you will get the error you're seeing here.
