Route-map and prefix-list
Answered Question
Nov 24th, 2008
Hi Gurus,
Will route-map and prefix-list command work together on bgp ? i tried using filter-list and route-map, they work properly. This is on outgoing.
tia.
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
Hello Jefferson,
Harold has provided the order in which the different filters are combined.
For outgoing the first filter used in your case is the prefix-list, the output of this filter becomes the input of the route-map filter.
The output of the second filter are the prefixes actually advertised to the neighbor.
Hope to help
Giuseppe
Overall Rating: 5 (5 ratings)
royalblues Mon, 11/24/2008 - 01:51
yes it will work
eg..
ip prefix-list default seq 10 permit 0.0.0.0/0
route-map ISP1 permit 10
match ip address prefix-list default
set local-preference 200
router bgp 1
neighbor x.x.x.x remote-as 2
neighbor x.x.x.x route-map ISP1 in
Narayan
jeffersoncbriones Mon, 11/24/2008 - 01:58
Hi Naraya,
what i mean is in the same line.
neighbor x.x.x.x route-map ISP1 out
neighbor x.x.x.x prefix-list SAMPLE out
how bout this?
tnx.
Harold Ritter Mon, 11/24/2008 - 05:52
Jefferson,
Yes, a route-map and prefix-list can be used in conjunction. Here what the order of operation will be for both inbound and outbound:
Inbound:
route-map
filter-list
prefix-list
distribute-list
Outbound:
distribute-list
prefix-list
filter-list
route-map
Correct Answer
Giuseppe Larosa Mon, 11/24/2008 - 06:10
Hello Jefferson,
Hope to help
Giuseppe
marikakis Mon, 11/24/2008 - 06:13
Hello Harold,
What you mentioned is also mentioned in the BGP FAQ (Q. What is the order of preference of attributes when some or all are applied to one neighbor in BGP?):
http://www.ciscosystems.com/en/US/tech/tk365/technologies_q_and_a_item09186a00800949e8.shtml#one
It also says there that a prefix-list and a distribute-list are mutually exclusive.
I just wanted to take the opportunity to report that in another part of the same BGP FAQ (Q. How can I filter all IP routes advertised to a BGP neighbor except the default route 0.0.0.0/0?):
http://www.ciscosystems.com/en/US/tech/tk365/technologies_q_and_a_item09186a00800949e8.shtml#fil
a different order is specified for inbound.
I think that the order of precedence of filters has changed at some point and not all relevant documentation has been updated.
Kind Regards,
M.
jeffersoncbriones Mon, 11/24/2008 - 17:07
Guys,
Thanks a lot, i've tested it and works well.
Here's my testing.
Outgoing:
prefix-list and route-map
tnx again.
