HWIC-4T total bandwidth
Nov 24th, 2008
I want to make sure what I read from data sheet. It says that each serial interface at HWIC-4T can support up to 8Mbps. Does it mean that if I use all the interfaces, total bandwidth will be 32Mbps or all interfaces will share the 8Mbps ?
As what I see at PA-8T module, only if 6 ports is 'shutdown', the remaining ports can support upto 8Mbps.
Thanks in advance.
royalblues Mon, 11/24/2008 - 02:13
  • Green, 3000 points or more
As per the data sheet it does support 8Mbps per port but most of the time the serial interfaces are not used above the T1/E1 rates.
Better to ask your Cisco SE to furnish some details of the testinf done for rates more than 2Mbps per port on these cards
Narayan
0600648902 Tue, 11/25/2008 - 19:50
I need you suggestion. What interface is best used to accommodate up to 8mbps of bandwidth ?
Thanks.
