PIX 515 boot in loop
actually i can't log into my device because it crashes while proceding my config file :
WARNING: The trustpoint will not be set for crypto map entry 'vers_partenaires3'
> , sequence number 84, as there was already a pre-shared-key specified for a peer
> in this crypto map entry. In order to initiate Isakmp tunnels using certificate
> s, the crypto map must indicate wh
> Thread Name: pix_flash_config_thread (Old pc 0x0085eefd ebp 0x02605f18)
> vector 0x00000003 (breakpoint)
> edi 0x02605cd0
> esi 0x00003a99
> ebp 0x02605c84
> esp 0x02605c78
> ebx 0x0168fe50
> edx 0x00000007
> ecx 0x0168fe88
> eax 0x27ba7755
> error code n/a
> eip 0x0107f79c
> cs 0x00000008
> eflags 0x00000046
> CR2 0x00000000
> Cisco PIX Security Appliance Software Version 7.2(3)
> Compiled on Wed 15-Aug-07 16:08 by builders
i dont' kwown how to fix it !!!
hello, thanks for you information about the password recovery procedure, but the actual problem is that my device boots with 7.2.3 version of software and starts to proceed my configfile that was imported from V6.3 and the device crashes while proceding the configfile so that i'm not able to type any command line into it in order to erase my flash of config file. so i was wondering how it was possible to clear flash without being logged into the device.
i have already tried the password recovery procedure, because i hoped that it coul'd help me to clear my config file
Best regards
During the bootup, press the esc key during the first 10 seconds. The boot process will look similar to this:
Cisco Secure PIX Firewall BIOS (4.2) #0: Mon Dec 31 08:34:35 PST 2001
Platform PIX-515E
System Flash=E28F128J3 @ 0xfff00000
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Flash boot interrupted.
0: i8255X @ PCI(bus:0 dev:14 irq:10)
1: i8255X @ PCI(bus:0 dev:13 irq:11)
2: i8255X @ PCI(bus:1 dev:0 irq:11)
3: i8255X @ PCI(bus:1 dev:1 irq:10)
4: i8255X @ PCI(bus:1 dev:2 irq:9 )
5: i8255X @ PCI(bus:1 dev:3 irq:5 )
Ethernet auto negotiation timed out.
Ethernet port 1 could not be initialized.
Use ? for help.
Now you can follow the password recovery procedure and boot without a config. Once the pix is booted, you can erase your old config by typing: "write erase" or "clear configure all".
Thanks, when i try to apply the upgrade procedure i have this message :
Received 2193408 bytes
Cisco Secure PIX Firewall admin loader (3.0) #0: Tue May 21 08:26:10 PDT 2002
Flash=i28F640J5 @ 0x300
BIOS Flash=AT29C257 @ 0xd8000
An internal assertion check has failed.
Copy the following message exactly as it appears,
along with any visible version strings, and
then call your support representative.
assertion "addr < STRATA_CHIPSIZE" failed: file "../flash/strata.c", line 222
i'am stuck in it. do ypu have any ideas ?
Pravin Phadte Sun, 11/30/2008 - 23:34
PIX has this problem.
1. It can be possible a hardware problem.
2. Software Image not uploaded or damaged.
1. Try to revert back to the old IOS running on the pix.
get the traceback logs from the pix after reload to troubleshoot more.
2. Try to reupload a new image.
