Re: How to study traffic flow between two routers ?
Nov 24th, 2008
I am planning to do a complex migration from frame-relay to mpls and need to know what kind of traffic is traversing this link ?
What are my options or tools that I can do to accomplish this ?
Pls advice,
Cheers,
- InternetB -
Overall Rating: 5 (3 ratings)
Joseph W. Doherty Mon, 11/24/2008 - 04:23
Not as good as Narayan's suggestion using Netflow, but if the router supports NBAR, you might obtain an insight into the traffic crossing the router too.
tcordier Mon, 11/24/2008 - 13:16
  • Bronze, 100 points or more
Last, and probably least informative, you can use IP accounting. You would need to deduce application flows from source-destination IP pairs, which is a downside, but it can be applied quickly, and does not need additional devices, like a netflow collector.
- Thomas
