6509 doesn't allow 'xmodeming' a new boot loader into MSFC
Nov 24th, 2008
Hi all!
I have a major problem with a 6509 supervisor engine (WS-X6K-SUP1A-2GE). I have lost the boot loader in the MSFC1 and I cannot upload a new boot loader image.
I run the supervisor switch engine in Rommon mode first and load the image from flash card (slot0:) manually with the command BOOT=slot0:c6sup11-jk2s-mz.121-26.E4.bin. After this, the supervisor gives command to the MSFC (router). At this point, I try to upload the boot loader with the xmodem function with the command 'xmodem -c -s9600' as specified in the instructions found on the Cisco website, but the upload fails after 7% of the upload is complete and the system crashes, giving out on screen the following error output:
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x61a38354
PC = 0x6012f818, Cause = 0x1820, Status Reg = 0x34018002
rommon 2 >
and returns into supervisor mode.
Please help! What is the problem? Thanks,
Stef
Giuseppe Larosa Mon, 11/24/2008 - 05:52
  • Hall of Fame,
    Founding Member
Hello Stefania,
notes
his procedure can take up to 35 to 45 minutes. Also, the first Xmodem transfer can fail with this error message:
"Error : compressed image checksum is incorrect 0xBAA10EAA
Expected a checksum of 0x6F65EA12
signal= 0x17, code= 0x5, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3040d003"
>>>Do not reset the RP. Issue the xmodem command again, and wait 35 to 45 minutes. This time, the transfer succeeds.
from
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml#xmodem
You need to do it another time
Hope to help
Giuseppe
Giuseppe Larosa Mon, 11/24/2008 - 06:32
  • Hall of Fame,
    Founding Member
Hello Stefania,
have you tried without resetting the RP at each attempt ?
If so I would ask for replacement (Cisco RMA or via a partner)
Hope to help
Giuseppe
stefania.castagnolo Mon, 11/24/2008 - 06:41
Hi giuseppe! Yes, I have tried but the switch was complaining about resetting...no reset, no reboot!
