Inbound and outbound traffic at the same interface
elecorbalan
I pass default traffic from inside to outside interface. Also I have to pass inside traffic back to inside interface to get some servers. I have configured default route to outside and a route to this servers subnet to inside.
route outside 0.0.0.0 0.0.0.0 --.74.49 1
route inside --.89.192 255.255.255.192 10.0.0.1 1
I have also configured
same-security-traffic permit intra-interface
clear xlate
But traffic icmp does not pass through and I can ping the server from the firewall.
Do I forget any command?
25 Replies 25
Farrukh Haroon
Can you give more details about the problem/topology...your question is not clear (atleast to me).
Farrukh
Yes, of course.
I have as default gateway for LAN PCs the inside ASA interface 10.0.0.22
But this PCs need access to server on a DMZ not configured in the ASA. The address to this DMZ is --.89.192 255.255.255.192
This DMZ is reached through the ASA inside interface.
To ping an DMZ server from a PC 10.0.0.114, the packet must arrive to ASA inside interface check a static route, and then get out from the same inside interface.
I can ping from ASA to a DMZ server, but I cannot ping from a PC to a server.
The config I have is:
interface Ethernet0/0
nameif outside
security-level 0
ip address --.74.50 255.255.255.252
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.0.0.22 255.255.255.0
access-list outside_access_in extended permit icmp any --.74.48 255.255.255.252 echo-reply
access-list inside_access_in extended permit udp object-group DM_INLINE_NETWORK_1 any eq domain
access-list inside_access_in extended permit tcp 10.0.0.0 255.255.255.0 any object-group DM_INLINE_TCP_1
access-list inside_access_in extended permit icmp any any echo
access-list inside_access_in extended permit icmp any any echo-reply
access-list inside_access_in extended deny ip any any
icmp permit any echo outside
icmp permit any echo-reply outside
icmp permit any echo-reply inside
icmp permit any echo inside
global (outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
priority-queue outside
tx-ring-limit 256
priority-queue inside
tx-ring-limit 256
class-map TunelVPNmap
match tunnel-group TunelVPN
policy-map TunelVPNpol
class TunelVPNmap
priority
service-policy TunelVPNpol interface outside
service-policy TunelVPNpol interface inside
how is there a dmz reachable on the inside interface of your ASA?
is there an internal router/L3 switch on your LAN?
Exclude this inside >> dmz traffic from NAT using nat exemption or add the following:
global (inside) 101 interface
NAT exemption:
nat (inside) 0 access-list NONAT
access-list NONAT permit ip
Farrukh
I still have the problem after doing clear xlate for modifying NAT.
Y have oppened nonat for:
access-list inside_nat0_outbound_2 extended permit ip 10.0.0.0 255.255.255.0 --.89.192 255.255.255.192
access-list inside_nat0_outbound_4 extended permit ip 10.0.0.0 255.255.255.0 --.89.192 255.255.255.192
nat (inside) 0 access-list inside_nat0_outbound_2
nat (inside) 0 access-list inside_nat0_outbound_4 outside
But when I send a telnet to a server --89.203
In ASDM logs I see the message:
%ASA-3-305005: No translation group found for protocol src interface_name:10.0.0.114/1710 dst interface_name: --.89.203/23
Remove this line and it should be OK
If it does not work...post the logs...and please don't change the 'interface_name' in the log. post the correct one.
Farrukh
It doesn't work. And I have passed the command
The logs are
3|Nov 25 2008|12:12:08|305005|62.97.89.203|23|||No translation group found for tcp src inside:10.0.0.114/1876 dst inside:62.97.89.203/23
3|Nov 25 2008|12:12:02|305005|62.97.89.203|23|||No translation group found for tcp src inside:10.0.0.114/1876 dst inside:62.97.89.203/23
3|Nov 25 2008|12:11:59|305005|62.97.89.203|23|||No translation group found for tcp src inside:10.0.0.114/1876 dst inside:62.97.89.203/23
4|Nov 25 2008|12:11:59|106100|10.0.0.114|1876|62.97.89.203|23|access-list inside_access_in permitted tcp inside/10.0.0.114(1876) -> inside/--.89.203(23) hit-cnt 1 first hit [0xd26734b7, 0x0]
Make sure the source/destination IPs in your NONAT acl are correct.
Secondly please clear connections and xlates on the firewall:
clear local-host
clear xlate
Farrukh
It is correct and I have don clear xlate and clear local-host ans no nat-control
But sill doesn't works
Ok then paste the output of the following command:
packet-tracer input inside tcp 10.0.0.114 1876 62.97.89.203 23 detailed
Farrukh
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in id=0xd5a654e0, priority=12, domain=capture, deny=false
hits=1080441, user_data=0xd4516260, cs_id=0x0, l3_type=0x0
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in id=0xd566de58, priority=1, domain=permit, deny=false
hits=522895, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 62.97.89.192 255.255.255.192 inside
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list inside_access_in extended permit ip 10.0.0.0 255.255.255.0 62.97.89.192 255.255.255.192 log warnings
in id=0xd58b39d0, priority=12, domain=permit, deny=false
hits=45, user_data=0xd5c89428, cs_id=0x0, flags=0x0, protocol=0
src ip=10.0.0.0, mask=255.255.255.0, port=0
dst ip=62.97.89.192, mask=255.255.255.192, port=0, dscp=0x0
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0xd5670928, priority=0, domain=permit-ip-option, deny=true
hits=10549, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip=0.0.0.0, mask=0.0.0.0, port=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 7
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
match ip inside 10.0.0.0 255.255.255.0 inside 62.97.89.192 255.255.255.192
NAT exempt
translate_hits = 57, untranslate_hits = 0
in id=0xd56ac6c8, priority=6, domain=nat-exempt, deny=false
hits=56, user_data=0xd5a93390, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
match ip inside any inside any
dynamic translation to pool 101 (No matching global)
translate_hits = 0, untranslate_hits = 0
in id=0xd45d1b80, priority=1, domain=nat, deny=false
hits=257, user_data=0xd45d1ae0, cs_id=0x0, flags=0x0, protocol=0
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
match ip inside any outside any
dynamic translation to pool 101 (62.97.74.50 [Interface PAT])
translate_hits = 853, untranslate_hits = 38
in id=0xd45d17c8, priority=1, domain=host, deny=false
hits=16941, user_data=0xd55170d0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 10
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
out id=0xd56ab510, priority=1, domain=nat-reverse, deny=false
hits=117, user_data=0xd45d1ae0, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Please add the global command I mentioned above.
Farrukh
RPF check drops because you have the following line
Since you mention ANY!, the return traffic gets involved in nat statement. Change it as
no nat (inside) 101 0.0.0.0 0.0.0.0
nat (inside) 101 10.0.0.0 255.255.255.0
