How to classify traffic in CBWFQ?
Nov 24th, 2008
Is it possible to classify traffic based on specific attributes of routes learned by BGP through CBWFQ?
I think answer is No as there is no option available under class-map to match traffic based on BGP attributes.
Also, we can match prefix with BGP attributes using route-map, however route-map can't be called under class-map.
Please let me know if I'm missing anything here or if there is a way to achieve this.
Sourabh
Giuseppe Larosa Mon, 11/24/2008 - 05:57
Hello Sourabh,
we have already talked about this.
Just another thought:
if you could do PBR with a route-map based on route tags and as action setting a qos-group you could on the outgoing interface use traffic classes that use qos-groups to define traffic.
However, I don't think that a route-map used for PBR allows to match on the route-tag.
This is something that should be tested
Hope to help
Giuseppe
Giuseppe Larosa Mon, 11/24/2008 - 07:50
Hello Sourabh,
I did some tests on this many years ago.
It worked if I remember correctly.
If applicable to your scenario it can be used.
It allows to mark traffic based on BGP communities.
Hope to help
Giuseppe
