Firewall 515E Can't Ping Interface
Nov 24th, 2008
Hello Guys,
I am new the whole Cisco firewall thing but do know routing and switching some what. I have assigned the config below on my firewall and a ip of 192.168.1.3 on my switch which is plugged into my interface. I can not ping the firewalls interface from the firewall ( interface E1) nor my vlan interface in my switch plugged into my inside interface port. My config is below. Please help. Thanks.
Ping Error
CharlesPIX# ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Firewall Config
hostname ChuckPIX
enable password 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
shutdown
nameif outside
security-level 0
no ip address
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
nameif DMZ
security-level 50
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
no failover
no asdm history enable
arp timeout 14400
route inside 192.168.1.0 255.255.255.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 192.168.1.10
dhcpd wins 192.168.1.9
dhcpd lease 10000
dhcpd ping_timeout 1000
dhcpd domain chuck.com
dhcpd address 192.168.1.11-192.168.1.254 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:d6f4b30b91f23020303a553ce4f214a8
: end
massimiliano.se... Mon, 11/24/2008 - 07:52
  • Silver, 250 points or more
Why do you have route inside 192.168.1.0 255.255.255.0 192.168.1.1 1 ?
Best regards.
Massimiliano.
Charlie Mayes Mon, 11/24/2008 - 08:42
I guess that would be wrong then right? What do I need to have?
when I removed it that route this is what it gave me as an error
ChuckPIX# ping 192.168.1.1
No route to host 192.168.1.1
ajagadee Mon, 11/24/2008 - 09:28
  • Cisco Employee,
Do a show interface and make sure that the iterface e1 in up/up status. It looks like a L1/L2 issue.
Arul
*Pls rate if it helps*
ajagadee Mon, 11/24/2008 - 11:04
  • Cisco Employee,
Interesting! Can you post the outputs of "show interface e1" and also "show route".
Arul
