WCS rf calibration, 'a' band not recording
Nov 24th, 2008
I have a WCS controlling 4402's running
I am using a AIR-CB21AG-A-K9 card (ver A0) with the latest drivers
When I try to do an rf calibration all I am picking up is the b/g bands - no 'a'.
The AP's are running 'a' and the PC card picks up the 'a' band, but it is not recording in the calibration.
I cannot figure out why 'a' is not showing up in the calibration. Has anyone seen this before?
tstanik Mon, 12/01/2008 - 07:44
Follow the steps below to adjust the properties of the RF calibration model.
Step 1 Choose Monitor > Maps.
Step 2 From the Select a command drop-down list, choose RF Calibration Models and click GO.
Step 3 Click an RF calibrated model name.
Step 4 From the Select a command drop-down list, choose Properties and click GO.
Step 5 Click the Sweep Client Power for Location check box if you want to enable. You may want to enable this if a high density of access points exists, and transmit power is reduced or unknown. The sweeping range of client transmit powers may improve accuracy, but scalability is negatively affected.
Step 6 Choose the binsize (4, 8, 16, 32) from the HeatMap Binsize drop-down menu.
Step 7 Determine the heatmap cutoff. A low heatmap cutoff is recommended, particularly if the access point density is high, and RF propagation conditions are favorable. A higher cutoff value increases scalability yet may cause difficulty when locating clients.
I hope it may help you
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
