joel@citadel Mon, 11/24/2008 - 12:32
I assume your ATA is registered and you are using the first line and you are trying to configure and use the second line.
CallManager displays each line of the ATA as a separate phone.
To configure the second line - Assuming your MAC address ends with ABCD, search for phones with device names ending ABCD01. It should already be registered, you would just need to configure the DN.
hope this helps
:JoeL
