Redundancy Solution needed.
Nov 24th, 2008
The LAN consists of two Catalyst 6500 switches running HSRP over a dual L2 port channel.
Eigrp protocol is running between the core switches and WAN router.
What configuration solution can I apply to provide redundancy between the core switches and the WAN router.
6509-A
int fa0/1
description Router-A (E0/0)
switchport
switchport access vlan 100
switchport mode access
interface Vlan100
ip address 10.1.1.2 255.255.255.0
standby 100 ip 10.1.1.1
standby 100 priority 105
standby 100 preempt
standby 100 authentication C1sc0
router eigrp 250
network 10.0.0.0
no auto-summary
6509-B
int fa0/1
description Router-A (E0/1)
switchport
interface Vlan100
ip address 10.1.1.3 255.255.255.0
standby 100 preempt
router eigrp 250
network 10.0.0.0
no auto-summary
Router-A
interface E0/0
ip address 10.1.1.253 255.255.255.0
interface E0/1
ip address
router eigrp 250
network 10.0.0.0
no auto-summary
Joseph W. Doherty Mon, 11/24/2008 - 16:46
"What configuration solution can I apply to provide redundancy between the core switches and the WAN router"
The single point of failure, I'm guessing you're concerned with, appears to be the single active Ethernet link on router-A.
The common solution would be routing. This could be done by placing the two router-A interfaces into different subnets, one connected to each separate 6500.
Other solutions might include: if you were running VSS on the 6500s, place the two Ethernet interfaces into a dual Etherchannel, one to each 6500; or perhaps bridging between the two Ethernet interfaces on router-A; or, if supported, load an Ethernet switch module into router-A and define a multiport VLAN (as you've done with the 6500s).
PS:
Of course, the WAN router itself will continue to be a single point of failure.
al.alexiev Mon, 11/24/2008 - 18:55
Well, there is no sense to use EIGRP or any other routing protocol between ONE router and ONE HSRP virtual switch! The only think you have to do is to put both Routers' interfaces in one BVI and to use IRB on L3 …
______________________
!Router-A
bridge irb
interface E0/0.100
encapsulation dot1Q 100
bridge-group 100
interface E0/1.100
bridge-group 100
interface BVI100
no shutdown
bridge 100 protocol ieee
bridge 100 route ip
… and that's all.
If there are any other networks around this picture (another Router interface to outside etc.) EIGRP could be used, but you don't need it for now.
