seting up a lab
Answered Question
Nov 24th, 2008
I set up a loopback0 as 192.168.22.2 /16
and when setting up a s0 w/ 192.168.22.3 /16 . I get
labr1(config-if)#ip address 192.168.22.3 255.255.0.0
192.168.0.0 overlaps with Loopback0
now I did chng loopback0 to 1.1.1.1 and I and I am ok , but just need to know why the overlaps
Correct Answer by Mark Yeates about 8 years 8 months ago
Routers will not allow you to have overlapping address space across multiple interfaces on the same router. Your subnet mask on loopback 0 covers IP addresses in the 192.168.X.X subnet, as does serial 0. You can change the IP address and/or subnet mask on either interface so they don't have overlapping subnets.
HTH,
Mark
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Yeates Mon, 11/24/2008 - 16:38
  • Gold, 750 points or more
HTH,
Mark
