Cisco ASA 5510 Ver. 8.0
We currently have an ASA 5510 setup for remote VPN purpose only. My question is, is it better to run VPN-POOL on ASA with the same subnet of the INSIDE interface or have the VPN-POOL on a separate subnet. I notice if we have the POOL on the same subnet as the INSIDE interface then VPN client also receives the INSIDE interface include in their gateway address VPN adapter.
Example
Outside IP 192.168.0.1
Inside IP 192.168.100.1
VPN-POOL 192.168.100.50-192.168.100.100
Or
VPN-POOL 192.168.200.50-192.168.200.100
acomiskey Mon, 11/24/2008 - 16:41
  • Green, 3000 points or more
Always separate. Use the 200 pool.
mkkeyan Mon, 11/24/2008 - 23:05
it will work, but you cna t access your inside hosts
