11-24-2008 04:42 PM - edited 03-06-2019 02:39 AM
I am trying to set up my old lab.. forgot the password. could not recover it.. I have Hp laptop with tera_term when I restart the router , I do BREAK no luck. I do ctrl+ breack,, no go.. any help please .. Thanks
Solved! Go to Solution.
11-24-2008 05:05 PM
I sometimes forget too. It happens when I switch between tera term and hyperterminal. Tera term does use a different break sequence than hyperterminal.
Good Luck!
Mark
11-24-2008 04:43 PM
The break sequence for tera term is ALT+B
HTH,
Mark
11-24-2008 04:51 PM
will try .. Thanks
11-24-2008 04:59 PM
cool . It works , I guess is the tera-term thing HUH !!!! :-)
11-24-2008 05:05 PM
Good Luck!
Mark
