Configuration register is 0xF
Nov 24th, 2008
Hi Guys,
I have made some changes to the switches and the I save the config. After few days there was an power outage and when the switches restarted it lost all the changes I made.
The switch is set to
what does the above mean.
If this is not correct what value should I used so that it can use the changes which I made next time when it reboots.
Tks
johnlloyd_13 Tue, 11/25/2008 - 08:43
  • Blue, 1500 points or more
what model and IOS for the switch? if it's a 2960, then 0xF is the default and recommended configuration register and is not changeable.
