External DHCP server
elecorbalan
I have configured a VPN with a DHCP server from the inside subnet. But messages from DHCP server don't arrive to VPN Client.
Do I have to confgure the ASA as a DHCP relay?
10 Replies 10
andrew.prince
Level 10
Level 10
Now I can't pass first IKE phase.
The logs are:
Nov 25 12:20:53 [IKEv1 DEBUG]: IP = --.176.85, IKE Peer included IKE fragmentation capability flags: Main Mode: True Aggressive Mode: False
Nov 25 12:20:53 [IKEv1]: IP = --.176.85, Connection landed on tunnel_group TunelVPN
Nov 25 12:20:58 [IKEv1]: Group = TunelVPN, IP = --.176.85, Duplicate Phase 1 packet detected. Retransmitting last packet.
Nov 25 12:20:58 [IKEv1]: Group = TunelVPN, IP = --.176.85, P1 Retransmit msg dispatched to AM FSM
Nov 25 12:21:22 [IKEv1]: Group = TunelVPN, IP = --.176.85, Removing peer from peer table failed, no match!
Nov 25 12:21:22 [IKEv1]: Group = TunelVPN, IP = --.176.85, Error: Unable to remove PeerTblEntry
The config is:
access-list inside_nat0_outbound_2 extended permit ip any 10.0.0.0 255.255.255.192
nat-control
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound_2
nat (inside) 101 0.0.0.0 0.0.0.0
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
access-list inside_access_in extended permit tcp 10.0.0.0 255.255.255.0 any object-group DM_INLINE_TCP_1
access-list inside_access_in extended permit icmp any any echo
access-list inside_access_in extended permit icmp any any echo-reply
access-list inside_access_in extended permit ip 10.0.0.0 255.255.255.0 --.89.192 255.255.255.192 log warnings
access-list inside_access_in extended deny ip any any log warnings
access-list outside_access_in extended permit icmp any --.74.48 255.255.255.252 echo-reply
access-list outside_access_in extended permit icmp 10.0.0.0 255.255.255.0 10.0.0.0 255.255.255.0
access-list outside_access_in extended permit udp 10.0.0.0 255.255.255.0 any eq domain
group-policy TunelVPN internal
group-policy TunelVPN attributes
dns-server value 10.0.0.9 --.89.253
vpn-tunnel-protocol IPSec
default-domain value --.es
What did you change?
I have change nonat rules but maybe something else. I'm not sure.
The messages isakmp are
pucca(config)# deNov 25 13:01:57 [IKEv1]: Group = TunelVPN, IP = --.176.85, Removing peer from peer table failed, no match!
Nov 25 13:01:57 [IKEv1]: Group = TunelVPN, IP = --.176.85, Error: Unable to remove PeerTblEntry
bug crypto isakmp 7
pucca(config)# Nov 25 13:02:22 [IKEv1]: IP = --.176.85, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 852
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing SA payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing ke payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing ISA_KE payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing nonce payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing ID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, processing VID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, Received xauth V6 VID
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, Received DPD VID
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, Received Fragmentation VID
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, IKE Peer included IKE fragmentation capability flags: Main Mode: True Aggressive Mode: False
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, Received NAT-Traversal ver 02 VID
Nov 25 13:02:22 [IKEv1 DEBUG]: IP = --.176.85, Received Cisco Unity client VID
Nov 25 13:02:22 [IKEv1]: IP = --.176.85, Connection landed on tunnel_group TunelVPN
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, processing IKE SA payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, IKE SA Proposal # 1, Transform # 9 acceptable Matches global IKE entry # 1
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing ISAKMP SA payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --176.85, constructing ke payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing nonce payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, Generating keys for Responder...
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing ID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing hash payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, Computing hash for ISAKMP
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing Cisco Unity VID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing xauth V6 VID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing dpd vid payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing NAT-Traversal VID ver 02 payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing NAT-Discovery payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, computing NAT Discovery hash
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing Fragmentation VID + extended capabilities payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing VID payload
Nov 25 13:02:22 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Nov 25 13:02:22 [IKEv1]: IP = --.176.85, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + HASH (8) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (130) + NAT-D (130) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 440
Nov 25 13:02:26 [IKEv1]: Group = TunelVPN, IP = --.176.85, Duplicate Phase 1 packet detected. Retransmitting last packet.
Nov 25 13:02:26 [IKEv1]: Group = TunelVPN, IP = --.176.85, P1 Retransmit msg dispatched to AM FSM
Nov 25 13:02:36 [IKEv1]: Group = TunelVPN, IP = --.176.85, Duplicate Phase 1 packet detected. Retransmitting last packet.
Nov 25 13:02:36 [IKEv1]: Group = TunelVPN, IP = --.176.85, P1 Retransmit msg dispatched to AM FSM
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, IKE AM Responder FSM error history (struct &0xd5a8ef30) , : AM_DONE, EV_ERROR-->AM_WAIT_MSG3, EV_PROB_AUTH_FAIL-->AM_WAIT_MSG3, EV_TIMEOUT-->AM_WAIT_MSG3, NullEvent-->AM_SND_MSG2, EV_CRYPTO_ACTIVE-->AM_SND_MSG2, EV_SND_MSG-->AM_SND_MSG2, EV_START_TMR-->AM_SND_MSG2, EV_RESEND_MSG
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, IKE SA AM:075789aa terminating: flags 0x0104c001, refcnt 0, tuncnt 0
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, sending delete/delete with reason message
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing blank hash payload
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing IKE delete payload
Nov 25 13:02:44 [IKEv1 DEBUG]: Group = TunelVPN, IP = --.176.85, constructing qm hash payload
Nov 25 13:02:44 [IKEv1]: IP = --176.85, IKE_DECODE SENDING Message (msgid=b12c3627) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Nov 25 13:02:44 [IKEv1]: Group = TunelVPN, IP = --.176.85, Removing peer from peer table failed, no match!
Nov 25 13:02:44 [IKEv1]: Group = TunelVPN, IP = --.176.85, Error: Unable to remove PeerTblEntry
I suggest you roll back your changes.
You should never make a change on a production system in working hours
You should think thru your changes
You should only make one change at a time
Jason Gervia
You don't need to configure the ASA as a DHCP relay in order for this to work. Remove the DHCP relay, and then configure a DHCP server under the tunnel-group, and the scope under the group-policy.
1) Create a DHCP scope on your DHCP server
2) Exclude one address from the scope
3) Make your ASA's scope the address you just excluded
4) Route that IP address (the one excluded from the scope) through your network such that packets destined to it will reach the ASA
This is because the ASA/pix will set the relay IP address to whatever you set in the scope on the pix/asa, so your DHCP server will respond to that address.
Ok, but now I have a worse problem, and it is that I can't finish IKE phase 1 because any fault in the config. You can see this in the logs I have posted before. Do you see anything missing in the config?
Finally, I have restored an ancient configuration and VPN ISAKMP works. I will open a new item for the problem with the DHCP server.
Thanks for all
