TACACS configuration on WAAS
Nov 25th, 2008
I am trying to configure tacacs on a WAAS device using 4.1.1c. I have configured the tacacs server to allow the user to login using privilege level 7 then the user is required to enable the device and login again to reach privilege level 15.
When ever i login then enable the device I am getting the following error
Error: Wrong Admin Password. Try again...
I can get the user to login straight to level 15 but this doesn't follow our security requriements.
has anyone seen this before or experienced this issue?
Matt
Zach Seils Sun, 11/30/2008 - 18:45
Matt,
The current TACACS implementation in WAAS supports command levels 0 and 15. Levels 1-14 are downgraded to 0.
Zach
