Archive: Partially Successful because VLAN config fetch not supported
Nov 25th, 2008
Archiving is working now, but RME shows failed job, because of VLAN fetch is not supported: (see underneath log fle)
1. 10.43.8.11 PRIMARY STARTUP Nov 24 2008 22:03:18 Successful
2. 10.43.8.11 PRIMARY RUNNING Nov 24 2008 22:58:27 Successful
3. 10.43.8.11 VLAN RUNNING Nov 25 2008 09:50:28 VLAN Config fetch is not supported using TFTP.
How can I disable VLAN config fetch ?
Joe Clarke Tue, 11/25/2008 - 07:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can't. VLAN config fetches can only be done over TELNET or SSH. However, if your switches use vlan.dat, then you really want to fetch this. If not, you will not be disaster-tolerant.
