VPN logs and details
Answered Question
Nov 25th, 2008
I have configured ASA 5550 as a VPN server. I want a software from which i get information which user is logged at what time, and this software maintains history also.
Correct Answer by ariesc_33 about 7 years 11 months ago
you may check on which specific logs you want to receive here
and you may enable the logging 113004 for example
logging message 113004
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 11/25/2008 - 08:34
Hello Waseem,
configuring a syslog server and an adeguate level of logging should be enough.
Kiwi syslog is a good syslog server that we use and it should be freeware
Hope to help
itdsmartnet Tue, 11/25/2008 - 22:07
hi Giuseppe
i have configured syslog server but i am unable to see any log. The following commands are entered under ASA 5550 for logging.
"logging on" , "logging host inside" Is there any other command in ASA required for proper logging?
itdsmartnet Wed, 11/26/2008 - 00:37
Thanks for your reply, Actually i have configured ASA 5550 as a VPN server and all remote clients are connected to it. Actually i want only those logs which tells me which user connected time and logged off time.
itdsmartnet Wed, 11/26/2008 - 03:01
one thing , how can i filter the log. "logging message " will enable or disable the log for that event id. i only want log to appear on syslog with event id e.g 113004.
ariesc_33 Fri, 11/28/2008 - 00:41
logging message level <0-7>
is that what you are looking for?
itdsmartnet Fri, 11/28/2008 - 03:52
actually i only want log for vpn nothing else. i have configured ASA5550 as a vpn server and my remote user and connected to it using cisco vpn clients. just want login time and logout time in syslog nothing else.
ariesc_33 Fri, 11/28/2008 - 07:38
im not sure of which of these logs you are looking to filter
