CME STCAPP feature code on FXS port
Nov 25th, 2008
I am trying to configure the feature access code for FXS port in the same CME. I try to follow "Configuring FXS Ports for Basic Calls" http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html, I met a problem. In order to enable service stcapp in the dial-peer, I need to remove the destination-pattern command. After I remove the destination-pattern and enable the service stcapp, CME does not allow me to add back destination-pattern. Thus if I can't enable the destination-pattern, how I could tell the CME to route the call to that FXS port? I also try the answer-address, changing the incoming called-number pattern and adding back the station-id in voice port, but I am getting busy tone.
I would like to check does anyone have any idea on how to successfully enable the feature access code on the FXS port on the same CME?
Thanks.
Hung.
ivillegas Tue, 12/02/2008 - 13:24
  • Silver, 250 points or more
To configure feature mode for SCCP analog phones on a Cisco voice gateway and enable SCCP analog phones to invoke features using standard FACs after hook flash, perform the following steps.
enable
configure terminal
stcapp call-control mode feature
end
Configuring Feature Mode:
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsfeatmd.pdf
