FXO lines - not able to make outgoings calls
sachin_mon
We are having one PRI line line terminated on Cisco 3845 rtr.Its works fine without any issue.We have just recently came up with 8 analog lines terminated on 2 FXO cards.We wanted to give FXO lines the first preference & PRI lines the second preference.
But somehow the calls are not going through the FXO lines.
1.We would like to know whether the configurations are correct.I have attached the template used for configuring FXO & the existing bkp without FXO line configuration.
2.We would like to know what type of cable is required as we have RJ11s at the patch panel & the voice router end.Do we need to use STRAIGHT RG11 cable or ROLLED RJ11 cable.
Rgds./
Sachin
8 Replies 8
jasoninbtr
Looks like you are using the default preference on the PRI (0) so it will take that one before it hits the FXOs.
You just need a straight rj11 base cord.
I would also recommend using the trunk group command. It is much cleaner config.
voice-port 0/2/3
trunk-group PSTN_FXO 1
timing hookflash-out 500
connection plar 100
voice-port 0/3/0
trunk-group PSTN_FXO 2
connection plar 100
voice-port 0/3/1
trunk-group PSTN_FXO 3
connection plar 100
voice-port 0/3/2
trunk-group PSTN_FXO 4
connection plar 100
voice-port 0/3/3
trunk-group PSTN_FXO 5
connection plar 100
dial-peer voice 1000 pots
trunkgroup PSTN_FXO
destination-pattern 9T
Hope this helps.
Jason
Thanks Jason for the update.
So, do we need to use the preference command on FXO ports if we are using trunk-group as I don't see it in your template ?
Rgds./Sachin
I'm not entirely sure what Jason was going after, but in your situation your configs will be a lot cleaner if you combine your FXO voice-ports into the same trunk-group.
# code
trunk group POTS
description POTS trunk group
# you can get really granular here and define hunt schemes as well
voice-port 0/1/0
trunk-group POTS
voice-port 0/1/1
trunk-group POTS
# etc
Then, you can also add your PRI B-Channels into a trunk group as well.
# code
trunk group PRI
description PRI trunk group
# you can also do this under the controller t1 section
voice-port 0/0/0:15
trunk-group PRI
Then you can define a single dial-peer per pattern, preferencing the POTS over the PRI trunk-groups as follows.
# code
dial-peer voice 1 pots
trunkgroup POTS 1
trunkgroup PRI 2
# with the 1 & 2 being the preferencing order
Hope that helps,
Will
The number after the tag is the preference within the trunk group. You could use a single trunk group if you wish.
trunk group PSTN
voice-port 0/1/0
trunk-group PSTN 1
voice-port 0/1/1
trunk-group PSTN 2
voice-port 0/0/0:15
trunk-group PSTN 100
trunkgroup PSTN
Just a different way to skin a cat.
Jason
Nice! I don't mean to hijack this thread, but I didn't realize that there was a preference parameter there. That's pretty neat.
cheers,
Will
Hi Jason,
Thanks for the update.
Why do we require the foll. commands
1.timing hookflash-out 500
2.connection plar 100
Rgds.,
Sachin
This is just the hookflash timer I find works best with my 1FBs.
connection plar 100
This is the extension that my POTS line rings down to. With regualar POTS lines there is no DID like there is with digital lines so you have to tell the router what extension to ring. You don't have to specify a PLAR if you are using MGCP but you do if you are using h323 natively or h323 fallback in SRST you definitely need to specify a PLAR. The only exception to this is if you are using analog DID in which case you can't place outbound calls on them.
Hope this helps.
Jason
Hi Jason,
I am using CCME.Do we require plar in that case?
Rgds./Sachin
