switch is dead... cant console, solid green SYST light....
Recently, our switch 3750 switch seems like its dead. It will not let me console in, and after i restart, the SYST light blinks for a few seconds then goes solid green... the switch will not respond... HELP!!!
wong34539
Level 6
Level 6
The problem may be in console port failure. I think you should contact Tac.
I've had a 3750 console port failure. When I attached it up to another switch and did a show CDP neigh detail, I also found out it had no ip address configured on it so I couldnt telnet to it. In the end, I joined it to another 3750 via a stacking cable, used a command to copy itt's IOS to the master and used it this way. I could then use the masters console connection.
calcan
Having same symptoms. How did you fix?
