DFM problems
Answered Question
Nov 25th, 2008
Hi, One of my customers has lms 3.0.1 with dfm 3.0.4 (recent update last week). This was a brand new install of LMS3. Around 2-3 months ago I applied the 2007 patch and then did software updates on the individual applications. RME & CM seem to be working fine, but DFM is having issues. The main DFM page says to look at the AAD.log in "High Severity Alerts" section (AAD.log attached). Log appears to be filled with java exceptions.
I checked previous posts on NetPro related to similar DFM errors, and I applied/verified solution, however nothing worked for me.
I most cased the reason of the issue was related to the name resolution, but in my case resolution works fine (Resolution.txt)
"pdshow" listing is also attached. Removing pidm.log doesn't work either, as after reload/restart this file appears on a system again.
I hope someone can give me suggestions where to go now :)
Seba
Correct Answer by Joe Clarke about 8 years 5 months ago
Then your database is most likely corrupt. Shutdown CiscoWorks Daemon Manager, and run:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 11/25/2008 - 07:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your EPM database is down. Do the following:
net stop crmdmgtd
del NMSROOT\databases\dfmEpm\dfmEpm.log
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\dfmEpm\dfmEpm.db
net start crmdmgtd
spasternacki Mon, 12/15/2008 - 15:58
Unfortunately it didn't work for me; I mean problem remains the same.
One of the dmf processes (I think it was dfmEpm) stuck in Starting phase.
Any further hints?
Seba
Correct Answer
Joe Clarke Mon, 12/15/2008 - 16:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
spasternacki Fri, 01/02/2009 - 08:39
Thanks Joe.
My DFM is up&running :D
Happy New Year!!!
Cheers,
Seba
