MeetingPlace Express 2.0 integration with Exchange
Nov 25th, 2008
Hi All,
We are trying to integrate MeetingPlace Express 2.0 with MS Exchange. All configuration for Exchange integration was done but when we click on the test button at the bottom of the page after a while the MPE system shows an error:
"Error while testing Exchange config parameters status=404"
Below is the log from the Exchange server:
Successful Network Logon:
User Name: MeetingPlace
Domain: PIC
Logon ID: (0x0,0x5694B63A)
Logon Type: 3
Logon Process: NtLmSsp
Authentication Package: NTLM
Workstation Name: PICUKEXC001
Logon GUID: -
Caller User Name: -
Caller Domain: -
Caller Logon ID: -
Caller Process ID: -
Transited Services: -
Source Network Address: <ip-address>
Source Port: 40255
Domain: PIC
Logon ID: (0x0,0x5694B67E)
Logon Type: 3
Does anybody have any idea what can be the reason of this error?
Thanks a lot.
joel@citadel Tue, 11/25/2008 - 09:25
I do not mean to misguide you...this is what I had experienced.
when I integrated MPE with Exchange 2007 and my version was not offically supported, the TEST option would fail, but when I try to schedule meetings from Outlook or through the web everything worked fine.
So even though the TEST fails, you can test it from outlook just to make sure.
make sure you have a separate account (e.g.ciscompe) in AD and Exchange that you use for the Unified MPE account, make sure the password is set to not expire.
Example settings:
Home --> System configuration --> Email service configuration --> Exchange Server Configuration
Exchange Server
Hostname * meetingplace.cisco.com
Cisco Unified MeetingPlace Express Mailbox Account
Windows domain * cisco.com
Username * ciscompe
Password *
Password confirm *
E-mail address * ciscompe@cisco.com
Mailbox maintenance interval (days) *
Mailbox maintenance cutover (days) *
:JoeL
calbertfusion Thu, 02/26/2009 - 17:23
Do you have IMAP protocol enabled in Exchange System Manager?
Have you tried restarting IIS services?
