N with controller 4402 with AP 1250
Nov 25th, 2008
Hi, I tried to use AP 1250 with a 4402 controler for use the N band. All the AP work fine with G but not with N. Somebody have this problem? Where I can find the doc for configure this.
Simon
Vinay Saini Fri, 11/28/2008 - 06:00
  • Cisco Employee,
Hii
dot11n rates will be availabe only with WPA2+AES security combination.
ALso make sur you have enabled the 11n support on the controller.Check the same under wireless->802.11b/g->network
Vinay
Scott Fella Fri, 11/28/2008 - 07:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Also configure the ap to use 40mhz channel width.... but remove the wpa policy.
Vinay Saini Fri, 11/28/2008 - 07:56
  • Cisco Employee,
Hii Fella5/Oscar
40 Mhz operation is not recomended for 2.4 GHz freq. , you can try that on 5Ghz.
But I guess controller still supports for both :)
Vinay
Scott Fella Fri, 11/28/2008 - 11:17
  • Hall of Fame,
    2017 Wireless
Sorry... didn't see that they wanted to run it on the 2.4ghz.
JEFFREY SESSLER Sat, 11/29/2008 - 17:18
Make sure that WMM Policy (under QOS) is set to allowed. WMM is mandatory for operation of "N" rates. Without it, you'll only get G rates in 2.4 and A rates in 5.
ssanscartier Thu, 12/04/2008 - 12:47
Someone have a web site or a file with the requirement for use N band with my hardware?
Simon
Vinay Saini Thu, 12/04/2008 - 19:47
  • Cisco Employee,
Hii simon ,
seems like ur problem is still not solved, can u pls attach the omnipeek capture for Beacons, probes and assoc handshake for ur client.
That will help us analyse where the problem is.
Also login to ur 1250 AP , if MCS rates are not allowed due to some config issue AP will generate message.
vinay
