traffic passed on PIX
Nov 25th, 2008
Can someone tell me if i need to check the following traffic is being passed on the PIX?
Source: x.x.x.246
destination: 172.18.46.75
what is the command to figure out on PIX?
& also need to check for hits on the access-list for:-
access-list acl-test permit tcp host grp1 host zb-nat object-group tcp_ports
please advise with the appropriate commands to run on PIX.
Thanks in advance.
Vin
vintan1801 Tue, 11/25/2008 - 09:21
appreciate for your timely response.
But can't we use capture command on PIX from source to destination?
Jon Marshall Tue, 11/25/2008 - 14:44
If you want to capture the actual traffic rather than just see if there is a connection then yes you could use the capture command to actually view the packets.
Jon
