LMS 3.1 & CUCM Cluster
Nov 25th, 2008
Does any one have a method by which to get my CUCM Servers registared to LMS so I can see Phone numbers.
I have the Servers Registared fine but can not see the CUCM Cluster I have seen other Conversions mention.
Ian
Joe Clarke Tue, 11/25/2008 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
In order for Campus Manager to manage CCMs, they must first have the SNMP service enabled. Next, if the CCMS are running 5.x or higher code, you will need to upgrade to Campus Manager 5.1.1 before they will be supported. Then, add the CCMs to DCR with the appropriate SNMP read-only community string. When all the CCMs are added to DCR, then run a new Campus Data Collection. They should then appear as green Application Service icons on the Campus Topology Map. Once that is happening, you can run a User Tracking acquisition, and the phones will show up in User Tracking.
Ian Beck Wed, 11/26/2008 - 03:05
Thanks for the info, I had all the pre-req's.
But did not have the SNMP Service started on the CUCM's, although I had updated the SNMP infor and the system reported it was restarting the SNMP Service.
Now seeing all the Phone info.
