DHCP server problem
elecorbalan
Hello, I try to establish an external DHCP server for a remote server VPN. With a capture, I can see packets going to DHCP server but I can't see any response from DHCP server.
How can I see response incoming in from DHCP server on my capture?
tunnel-group TunelVPN general-attributes
default-group-policy TunelVPN
dhcp-server 10.0.0.4
The capture is
30: 18:18:52.662380 10.0.0.22.68 > 10.0.0.4.67: udp 548
31: 18:18:55.659694 10.0.0.22.68 > 10.0.0.4.67: udp 548
32: 18:18:59.659694 10.0.0.22.68 > 10.0.0.4.67: udp 548
33: 18:19:04.659694 10.0.0.22.68 > 10.0.0.4.67: udp 548
5 Replies 5
elecorbalan
I think I should get a broadcast like this:
34: 18:20:43.277375 10.0.0.2.138 > 10.0.0.255.138: udp 239
35: 18:20:43.277451 10.0.0.2.138 > 10.0.0.255.138: udp 208
36: 18:20:46.309386 10.0.0.2.138 > 10.0.0.255.138: udp 239
37: 18:20:46.309447 10.0.0.2.138 > 10.0.0.255.138: udp 208
38: 18:24:49.758871 10.0.0.2.138 > 10.0.0.255.138: udp 239
39: 18:24:49.758948 10.0.0.2.138 > 10.0.0.255.138: udp 208
are you using the ip helper command on your firewall?
with IPsec, you can only turn a broadcast into a directional
broadcast with the ip helper
address command on the inside of your source.
There is no ip helper command on ASA
then try configuring it because the dhcp request is a broadcast and it wont reach the other site without the directed broadcast
Finally,
It is right to send a unicast.
But I can't receive any response from the server.
Maybe I have to configure a DHCP relay, do you know if it is needed to configure a DHCP relay? Because I have to unconfigure DHCP server from VPN tunnel-group to configure DHCP relay.
