IPSec error
we are using Cisco 7206 router with VAM2+ module. the output of the command "show crypto engine accelerator statistic" is included in the attachment.
I want to know In the output of "show crypto engine accelerator statistic" command, what is the significance of "ppq full errors" and "replay errors" and how can we reduce them?
Also The CPU utilisation of the router is going above 60% frequently, what is the reason?
This is urgent so please suggest
Giuseppe Larosa Tue, 11/25/2008 - 10:29
  • Hall of Fame,
    Founding Member
Giuseppe Larosa Tue, 11/25/2008 - 13:14
  • Hall of Fame,
    Founding Member
Hello Rakesh,
here is the link to the command reference of
show pas vam interface
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s5.html#wp1016563
ppq_full_err
Number of packets dropped because of a lack of space in the packet processing queues for the VAM. This usually means that input traffic has reached VAM maximum throughput possible.
pkt_replay_err
Counter that is incremented when a replay error is detected by the VAM
These are for VAM but I think they apply to VAM2+ the names are just a little different.
Verify with the datasheet I provided in the other thread if your traffic volume is more then the declared performance.
However, your bigger problem is the very high cpu usage.
I would investigate that first use the second link in the post in the other thread for this.
Hope to help
Giuseppe
